I often experience that Nomad undo when I rest my hand on the screen.
I’m left handed and I use an iPad Pro and apple pen. Does anyone know if there is a way to reduce that?
Jorgensen
Jorgensen
Under Interaction->Use size rejection. You have to change it every time you launch, but it will reject input that’s larger than the Pencil (like fingers/palm)
Adjusting the “Use size rejection” helped. Thanks.
Where is interaction.?
I am new to this sorry. I am using android and i don’t see this feature.
At the top of the screen, right next to “Display Settings” (the usual cog icon), you will likely see three horizontal lines with circles. That will be the “Interface” menu. When you click on it, you will then see the “Gesture” menu right next to it. At the bottom should be “Palm Rejection”.
I’ve honestly gotten used to keeping it off. Took a while to train myself to stop hitting the screen with my palm here and there, but it’s possible.
To prove that you’re a true digital sculpting dweeb, you need one of those partial gloves that all the streamers use:
