The shortcut gestures for undoing and redoing history when doing view zoom, especially the undo determination for two finger taps on the screen were too sensitive and often misused, and now the shortcut gestures for history have to be turned off. This situation is worse for girls who have worn a manicure! Feedback has been received from many students.
Same issue for me on the iPad.
Hard to tell in what way it’s accidentally activated
Maybe the minimum finger movement required to activate pan and zoom could be made configurable by the user, as sort of a “tap sensitivity”.
You can try deactivating “long press” in the gesture settings too
Interesting too to hear it’s being used in a school setting would be cool to hear more about it
Yes, long presses were actually turned off a long time ago due to being too sensitive, but it’s even more inconvenient to have two-finger taps and three-finger taps turned off again because they’re now also very sensitive and easy to accidentally touch.
Yeah, I’ve got that set to 80 and it definitely does help but I still undo without meaning to. I’ve gotten kind of used to it. The same thing happened with Krita but remapping undo to 3 solved everything. Super helpful.
