Bug reports
I don’t know if it’s a bug or not but with several of my models I tried to export them to my pc but it seems that these being too big just don’t want to open anywhere other than in nomad . So I tried by reducing the resolution of the meshes and strangely around 200mb it is exported without errors but obviously I lost details
I need more information,
What file format? What software?
Did you try to reimport it in your iPad then open them in Nomad again?
So, I tried in Gltf in Obj and Stl and no file opens on for example Forger (in obj), Zbrush (in obj it crashes the application) Mixmesher (in Gltf) the simple 3d viewer of windows . On the other hand Blender seems to want to open the gltf. The I did the test I can easily re-import the large files into nomad. I did another test by doing a remesh voxel on my object so as not to lose too much detail, I exported it in OBJ the Forger oddly opens it but still not the others. Blender doesn’t want the smaller object either. I didn’t have this problem with my first projects.
news : I thought the problem was with my usb stick because when I wanted to re-import the big 333mb file from my usb stick in nomad there was nothing showing, like the big file didn’t contain any object. I tried again immediately after in Forger and it indicated that my object did not contain any vertices etc … and therefore it would not be imported. But I can see that if the file is around 200mb, it works in obj everywhere.
Problème de clef USB à mon avis.
Si tu arrives toujours à reproduire le bug, essaye de créer un (gros) OBJ à partir de forger. Tu verras si ça marche ou non.
Pour forger, tu as mis le fichier sur ta clef USB auparavant?
Je pense que ça vient de la clé usb mais plus précisement du système de transfert de fichier de l’Ipad. Je pense qu’en fait quand le fichier est gros il ne t’indique pas vraiment quand c’est transféré tu dois aller le vérifier et j’ai cette impression que le fichier n’est pas totalement copié mais que l’ipad te l’affiches quand même dans la clé usb comme si c’était bien copié. J’essayerais tantot avec un gros fichier provenant de forger
Je n’ai pas de clef usb mais j’ai eu des retours sur des soucis de clef USB.
Le problème vient très probablement de l’iPad en effet, je ne sais pas s’il y a un moyen de régler le problème.
non je pense que leur système pour les fichiers et mal fichu, windows fait un Ding quand que fichier est totalement copié mais dans l’ipad tu n’as rien même pas un message et je crois que ça vient de la plus le fait qu’il a du mal avec les gros fichiers en usb
I gave up on USB to transfer. I had several issues as well with inconsistent file sizes and nothing rendering on the PC. I set up my iTunes on the PC and synced it. I downloaded File Master which shows up in the file sharing in iTunes (native Files app does not which is stupid). I then save the file from file master to my PC. I have had no issue while doing this.
@stephomi J’ai essayé avec un objet créé dans Forger a une très haute resolution, je l’ai exporté en obj il fait 376Mb et je peux l’ouvrir depuis ma clé usb partout. Il faudrait que d’autres utilisateurs d’ipad pro test avec une clé usb-c moi j’utiliser une usb-A avec adaptateur usb-C.
J’ai refais un dernier test en réimportant depuis la clé usb le même fichier dans nomad, j’ai fais deux traits de peintures pas plus j’ai réexporté en obj (en sauvegardant d’abord sur l’ipad sinon c’est long) ensuite je transfert sur ma clé usb le nouveau ficher qui fait 50mb de moins et je remarque une chose c’est que déja ça prend plus de temps, j’essaye de réimporter dans forger et biiiim il dit qu’il n’y a pas de vertex pareil sur mon pc. Donc je pense qu’il doit y avoi un petit problème pas trop grave sur nomad.
@stephomi ma théorie est apparement correct, ça ne vient pas de nomad finalement. Je pense que en fait le transfert de fichier continue même après qu’il soit “copiés” pour faire le test j’ai pris un clé usb avec une led bien bleue qui clignote quand il y a une activité et j’ai remarqué que même l’apparition des fichiers sur la clé usb (comme si la copie était finie) la led continuait a clignoter au moins 40 secondes. Bref ça marche mieux avec une clé munie d’une Led lol
