I figured it would be worth a shot to state that Adding a Snake-Hook tool would be freaking amazing since I use it soo much in Zbrush/Blender. Thoughts ?
There is a snakehook brush ![]()
Put dyntopo(in the topology menu above, the dyamand-symbol) on and use the drag brush.
On the new Ipad Version this brush is even better than snakehook because u r able to rotate the pen/brush ![]()
Don’t have that iPad.
With Android, use drag / move with your finger.
You can use the finger of your 2nd hand to create the swirl effect.
Unfortunately, Android does not support pencil and finger at the same time - hence the detour with the finger.
The Pro Pencil on the iPad doesn’t need a second hand either because the Pro tip rotates the brush.
