I wanted to share a little trick my friend taught me! I’ve been using it to create curled petals, flowing skirts, and all kinds of twisted shapes!
All you need is the Elastic brush! This also works with the Drag and Move brushes.
How to do it
For Apple Pencil (1st & 2nd Gen):
Select one of the brushes mentioned above and adjust the brush radius to control the area you want to affect.
Place your Pencil on the model, right at the center of the area you want to rotate.
Keep your Pencil touching the screen, then use a finger on your other hand to swipe across the screen.
The surrounding mesh will rotate around that point, allowing you to twist the shape!
For Apple Pencil Pro:
It’s even easier!
Adjust the brush radius and place your Pencil on the model.
Simply rotate the Pencil around its own axis while keeping the tip in contact with the screen!
My friend calls this the “friction fire-starting technique” (钻木取火), LOL
What can you make with it?
You can use this technique to sculpt croissant-like shapes, curled rose petals, twisted fabric, and so much more!
It also works great for subtle, localized adjustments, like the curled details and flowing skirt in my first two screenshots.
A little heads-up!
This technique can stretch and distort your mesh topology quite a bit, especially with larger rotations.
I’d recommend using Quad Remesher or Voxel Remeshing afterward to redistribute the polygons and clean up the mesh.
That’s it! It’s a super simple trick, but I’ve found it really useful for sculpting organic, flowing shapes.
Huge thanks to my friend for teaching me this!
You can find her on Xiaohongshu (RedNote): @美味手抓饼呀
Hope this helps someone! Happy sculpting!
