This one isn’t free I’m afraid, but a lot of time and effort has gone into making it.
(ArtStation has a sale on from the 27th Jan - 4th Feb where there will be a discount if you would like to take advantage of that. I will also let you all know about future site sales if you would like… SEE NEW LINK IN REPLY BELOW)
I’ve been working for a while on creating tools to use within Nomad, rather than much sculpting as I like to solve problems and make my life easier in future.
I’m experimenting with more packs like this and will share them with you all in time.
With Nomad Sculpt, it’s better to say Tool instead of Brush. For example, if you load the modified clay tool including an alpha, then the settings of the tool are also saved - e.g. stroke spacing, pressure, falloff …
The alpha is just an image that can be used in multiple tools. If you load this alpha e.g. into the Clay Tool, then you have to find the settings yourself…
Holger_Schoenischka makes a fair point … they’re not technically ‘brushes’. I suppose my calling them that is a hang up from using other software.
A simple way to think of the difference
Alphas are an image that are the ‘shape / pattern / texture’ on a ‘rubber stamp’.
The tool / brush is all the settings of how the alpha effects the surface, and different tools work in different ways.
For example the inflate tool will ‘blow the surface up like a balloon’ in all directions. We’re as say the layer tool will create a ‘plateaued’ surface.
What I have created with my brushes is custom alphas with fixed tool settings to give a specific result or way of working to get the results I wanted (these are of course fully editable as are any tools and brushes).
But ultimately things like this are either useful to people, or they’re not
Apologies I’ve only just noticed this. The ArtStation sale is only available through the ArtStation site. So this is the link if you want the discounted price till the 4th Feb https://www.artstation.com/a/12088381
I thought as my site is hosted by ArtStation my site would show the sale, but apparently it doesn’t do that.
Hello Gary, purchased!
With the hype I purchased just read the frist post you don’t worry about put a price to your work Can’t wait to play with this new alphas and brushes.
