(I tracked this down a bit more so I think it’s worth opening a bug report now…)
There’s a bug when there are more than 2 bindings with unrecognized keys (Scan_XXX)
For example:
Smooth → Scan_313
Mask → Scan_319
Gizmo → Scan_386
After a restart, I can only use the initial key I press of these 3 bindings. The other keys trigger ALL the remaining keys at once.
Example:
Afer a restart, I press the key for Smooth. This works, but when I press the Mask hotkey after, both Mask and Gizmo are triggered at the same time and the behavior stays like that.
or:
After a restart, I press the key for Mask: This works, but when I press Gizmo, both Gizmo and Smooth are triggered at the same time.
I hope I could make myself clear, let me know if I can provided additional data.
I think I found the issue, the culprit seems to be the gesture menu itself.
Try to trigger all the scan key before opening the gesture menu, it should work.
Scancodes are working flawlessly already version 1.68. Thanks again . Tabmate is a great companion to Nomad, makes the sculpting process even more fluid.
