It seems that most discussions has swept to discord.
But maybe someone is interested to contribute here as well.
So here is my first feedback:
New Primitive controls are AWESOME!!
The only conflict I see is overlapping with transform controls.
This can be confusing for newbies. On the other hand:
Enabling & disabling “edit” is very quick now.
You can use web discord @knacki if you don’t want to download the app.
Discord (this the right one need to register though, previous the login button is gone when not using pc that’s what I thought)
After that click this one: Nomad Sculpt
Well my suggestion on discord, should be off by default for primitive control point(edit). So it won’t overlap. And new user can tap edit widget to check what is that
About the transform control (gizmo?) it was base on vote.
The ‘add/sub’ binding isn’t working in conjunction with mask and smooth when mapped to the ‘Alt’ key (default). When bound to other keys (tried ‘M’), it works fine. Also it works fine when holding down ‘alt’ during a masking/smoothing operation but only for the current stroke, not for existing ones (which would be an interesting feature in itself!)
(not being on either discord or the beta I’ll just unbury this old thread)
