Could incremental snapping when rotating an object be a possibility in the future?
It’s not very intuitive but if you select the gizmo you can set a rotational snap with the slider on the left.
I was using the slider on the left for snapping, but I found it difficult to dial in to the number I wanted. If there were a way to enter the number manually in a text field or a way to slow down the slider like Procreate (the further you pull the pencil from the slider, the slower the slider moves), that would be helpful.
O.k cool. Thanks!
The sliders in Nomad work in the same way as Procreate - pull away from them and get more accuracy.
True but it’s disabled for some sliders, for example the gizmo rotate one.
