Project/Attract Brush
Hi,
Would it be possible to add a brush similar to the ZProject brush in ZBrush? I often need this brush in many of my models. Because of this, I have to switch to another application. However, Nomad Sculpt is much better in many aspects. It would be great if such a brush could be added as well.
Thank you!
Nomad selmask & extract is pretty much the same & in some ways better
Actually, it’s not quite the same. I take 3D scans of individuals and design custom orthotic models tailored to each person, and sometimes even millimeter differences can cause problems. So, if I make changes to the model after extracting it and the product doesn’t fit the surface perfectly, I have to go back to the masking stage. Brushes like ZProject are very helpful in this regard.
I’m really looking forward to this tool too, and for now I have to use Forge or Zbrush.
I agree, it’s not the same at all :rofl:
I looked at an example of Zproject and it can’t have been correct!
The closest tool in Nomad would be to mask the parts you don’t want to change and then do a reproject vertex from the misc menu.
I think being able to do that using a brush tool would be great in Nomad :+1:t2:
I just had a look through my YouTube searches and I had looked at the Zbrush mesh project brush :grimacing:
