First I wanna thanks developer, this app with post effects is a killer hehe…
And it can be the best app ever, with some adds it even can beat Zbrush in the future.
This is the list I gathered with first days of using Nomad.
I will be add here my suggestions:
Scene menu:
When I start sculpting and splitting objects to smaller parts I found in the minute I have thousands of parts, uff,
We need there Groups, add/remove objects to groups, select them, every group should have own pivot/gizmo to manipulate more than one object in the same time.
Voxel menu:
We need some kind of automatic retopology, like Zremesher, but something simple and effective.
Tools:
Insert tool - possibility to clone object pick from Scene objects, and from import .obj,
and set its size before you clone.
PreStamp tool - to catch own sculpt to alpha on proper height and intensity,
something you click it and pop out a plane or box in proper place and size and camera view,
you just sculpt on it, click “get alpha” and save menu appears…
Tube tool - in advanced version, when you create a tube points,
tool generate clones in chain from selected mesh,
also predefined diameter shape from alpha/object to pick, not only default circular tube shape,
and should have diameter on point to set before click,
Stroke and Brushes: - most important to me
to create awesome brushes we need more functions in stamp stroke, we need rotation/random rotation,
scale/random scale, brush should have in background pick this info from sliders,
under tiling random slider, depth slider for alpha, and direction like in Zbrush…
Also when we save brush, it’s should remember pressure radius/intensity settings on/off…
Background menu:
Reference image should scale with object you sculpt in the same time.
Camera menu:
Orbit mode as default,
also I would like to have (I’m left handed), in right bottom corner below material pick buttons, own set of buttons,
for example 4 in row or 2 columns, which I could fast change saved cam views or most used tools/brushes,
in left hand I have pencil, so right is free and ready to click…
OK, this is all for now, when I discover more I will get you more…
