Polygon TRIM Tool does not have pointed corners?
Hi people!
I’m new to Nomad Sculpt and the forum, and I was wondering if anyone could help me out.
I was trying to create a ‘Z’ like shape and didn’t really know the best way to create it, so I thought of using a ‘BOX’ shape and then using the ‘Polygon Trim Tool’ to cut it out but the ‘Polygon Tool’ has rounded corners and I just want sharp pointed corners which I had seen on Youtube tutorials such as Southern GFX (Nomad sculpting app - Using the Trim Brushes in Nomad - YouTube). Is there a way to make the rounded corners just go to a point?
Also if anyone knows of a better way of doing this shape then please could you let me know as it would help me out greatly.
Cheers
Diege
You can tap once on a control point (white point) to make it sharp.
However the Trim tool is limited, it doesn’t always work well, so you might not keep a sharp corner after the trim.
Maybe it will be improved in the future.
Thanks Stephomi, that worked!!!
