Poly Tools, Again. But…
…the following is based my attempts at learning ZBrush and Sparseal’s Uniform. One is an industry standard, the other was my next best hope at box modeling on my iPad Pro. Both apps are a virtual slogfest through a swamp of terminology and hidden functions in order to achieve anything resembling a usable workflow on the iPad. Convoluted terminology and pointless documentation are the hallmarks of both apps.
In my research into ZBrush, I discovered the Face Groups in Nomad. It was a game changer when it came to trying to control the mesh and its retopology using Quad Remesher. Hacking into the jungle that is Uniform gave me insight into the possible workflows available on the iPad, as well as an understanding of Tools in general.
Based on all that, there are only three things, three Tools specifically, that keep Nomad from replacing ZBrush and Valence 3D on the iPad, and possibly ZBrush and an entire list of modelling software for desktop:
-Loop Cuts - The ability to add a single loop of Vertices/Edges to a mesh without separating it would add a whole new level of control, especially for the hard surface modeling crowd. The addition of a companion Knife Tool for adding quick bits of geometry wouldn’t hurt either
-Extrude - The ability to select a Face Groups and Extrude it without having to go through the Mask numerical interface would add a new level of control that is currently found only in desktop apps and in the theoretical interface mire that is ZBrush. I know the effect can be simulated with the careful application of Tubes, but being able to simply Extrude at will would be a welcome addition.
-Multi/Split Window/View - being able to observe changes to the mesh in one view by seeing the mesh from a completely separate but simultaneous view would be a massive benefit. It is the functionality that I have tried to replicate via instances, which is a massive uphill climb in workflow terms micromanaging an instance to mimic a separate viewport is not worth the anguish Even a simple 4-way top/bottom/side arrangement would be great
I know that Quad Remesher became available via paid plugin. Is the same possible with ideas i just mentioned? If you could partner with Sparseal and add CozyBlanket as another mode inside Nomad, the 3D industry as a whole would skid to a stop to stare at the result, and quake in their boots as they did so.
Its missing a lot more features to compete with industry standards, look at my post. Those options are basically in zModeller brush in zbrush and its easy af to use.
I’ll have to take ZBrush lessons from you then, because I don’t understand that aspect of the software at all. I was ‘raised’ on Blender terminology and I’m used to Nomad in practice. I don’t even know how t ask the ZQuestions I have. It’s like trying to learn Japanese by running around the street, pointing and grunting.
