Nomad Change Log
1.91
ios: improve quad remesher guide handling when symmetry is enabled
gizmo: add new target mode with sync instance
insert: fix previewed insertion when inserting on a repeated instance
insert: fix crash when inserting a node while instance option is on
insert: insert the nodes as a child instead of next to the picked object
insert: tries to keep hierarchy when inserting subpart of a tree selection
silhouette: fix option when mesh isn’t aligned (transform not reset)
silhouette: fix option when mesh has a non identity transform
ply: fix export when objects have transform
ply: fix export when exporting multiple objects
fbx: improve import
fbx: add basic export support (no textures, no materials)
tube: prevent profile editing if the profile is aligned with the camera view
tube: only snaps the first point of the tube when creating a tube and if the snap option is off
tube: fix cap triangulation sometimes failing in some cases
tube: snap can snaps on other object vertex
bake: fix self vertex baking in some case
bake: fix crash when a mesh has a normal map but without UV
bake: show offset preview
interface: quick mask or smooth shortcut sometimes didn’t work if tools were re-ordered
interface: add checkbox to disable long press undo/redo
interface: add alternative color wheel picker
interface: improve material and tool alpha preview
wireframe: only show wireframe on visible faces (can be changed in wireframe option)
wireframe: add an option to only show wireframe for the current selection
symmetry: fix flip option
symmetry: more robust handling by sculpting brushes
mask: mask shape selector can now clear and mask multiple objects at the same time
mask: masked area will ignore transparency and be visible (hidden face data will still be hidden though)
mask: clear mask even if the mirrored shape collides with the mesh (when the main shape doesn’t collide with the mesh)
move: fix background radius when mesh has non uniform or skew matrix
move: add swirl effect when using a secondary finger or input
facegroup: add auto group from normal option
facegroup: add auto group from separate parts option
multires: add a wireframe option to only show the first level wireframe
multires: add an option to lock the vertices of the first level
triplanar: add brush material triplanar mode
triplanar: add mesh material triplanar mode
tool: add extra contextual options to facegroup, mask and hide
tool: preset can be moved in subfolder
layers: add an option to extract a layer from the base painting, by comparing with a default material
dyntopo: fix bug that could make sculpting fails the surface picking
curve: revert behaviour of path drawing mode where new points can be inserted from dragging anywhere
xray: add target option to choose whether the selected or non selected objects are ghosted
file: update obj vertex color import if the file is coming from blender
tool: presets can be loaded through drag n dropping or import button (Project menu)
alpha: add screen projection option, instead of surface
repeater: tweak default mirror and radial initial world position
texture: matcap supports color texture
image: improve EXR support
1.92
android: fix big performance issue when moving the camera
ios: fix crash on iOS <=15.2
toolbox: dot not display tools in subfolders
toolbox: add an option to rename folder
tool: fix stroke painting checkbox not being read correctly at loading
tool: fix layer tool
dyntopo: fix issue for some tools
boolean: remove unwated plane simplification cleanup
voxel: bake texture to vertex from multiple inputs
inspector: fix crash in some case
image: add support for webp format
triplanar: fix alpha and paint triplanar preview when mesh is instanced
delLayer: fix crash when painting is off
gizmo: adding a pin option so that releasing it will copy the pivot
tube: fix rotate handler being too fast when radius is very small
interface: add a small indicator in the the scene list when shading Instance ID or object ID is used
1.93
boolean: fix edge issue
split: fix line bug
tube: fix twist control speed
tools: remove empty folder to not clutter the filesystem
background: fix overlay not working with inspect or face group view
outline: fix issue with facegroup and inspect mode
tool: fix tools folder being deleted if only subfolders were present
measure: improve line thickness consistency
bake: support triplanar normal baking
bake: support flip y option
uv: improve degenerate face when merging duplicate UVs coordinates
snapcube: interacting with small buttons now prevents the view from changing. Mostly useful with pencil and grid snapping where a view change could exit orthographic
tube: tube profile xy mirroring
tube: tube profile transform
falloff: fix jitter scale
stroke: fix roll mode
layer: add channel blend settings
render: reduce banding caused by low depth precision
binding: fix custom tool bindings
pencil: fix small interaction threshold issue with Drag and Move tools
shading: fix crash on uv unwrap or inspector when shading texture is disabled
facegroup: fix crash on undo when using finger to convert mask to group with sculpt finger off
extract: fix crash when extracting the mask and opening the post process settings
icon: fix custom icon on some tools when the ui is on light mode
paint: stop painting everything in yellow
subsurface: fix effect when multiple object have different scattering in the scene
primitive: expose division control in the contextual menu
voxel: hole filling will reuse voxel edge length
lathe: improve axis editing
render: fix normal map rendering where there is skew and non uniform scale
render: better smooth normal and tangent, especially when strong skew and non uniform scale is present
bake: normal baking improved when skew and non uniform scale is present
subsurface: fix scattering effect
obj: fix normal map import and export
operation: add global mesh operation menu
curve: add spiral option to curve repeater
material: toggling embed texture doesn’t force or delete alpha on existing materials
profile: fix preset selection sometimes not working
profile: fix bugs when using mirroring
hide: fix facegroup view ignoring hidden faces
background: improve a bit background and layer base dropper preview
interface: small improvements for small screen and fixes glitches in the scene menu
layer: fix bleeding issue on layer when using screen smooth or blur operation
operation: fix color operation on layer mode
mask: fix mask not working correctly with connected topology (for example move tool)
operation: improve blurring on mask area
hide: fix sculpting not working correctly caused by wrong handling of stroke spacing on hidden area when show hide is off
connected: fix connected topology not respecting disabled mask, face group and hidden faces options
repeat: add random option in repeaters
show: allow contact shadows even if screenspace shadows are used
material: add copy and paste button
toolbox: add resize handler
interface: add most bindings as customisation for the bottom bar
facegroup: fix render artefact on grazing angle normals
pivot: fix pivot editing on multiple mesh
pivot: repeat randomness now uses mesh pivots
pivot: add option to mesh vertices from pivot
paint: fix texture popup
tube: fix preset popup
binding: fix hide clear all
repeater: fix repeater not working directly when adding it to the scene
shortcut: fix some bottom shortcuts not being saved
ios: add postprocess denoiser (oidn)
postprocess: fix ssr for refraction material
boolean: fix crash when running boolean on a single mesh
culling: fix front-vertex shape operation in case of transform with non uniform scale or skew
material: add shadow catcher
fbx: fix crash at loading
light: improve angle and size parameter support
baking: imrpove normal baking on very low poly mesh
shortcut: improve bottom shortcuts ux
locale: add czech, dutch, hebrew, swedish
locale: fix arabic ligature
ply: fix ascii import
usd: fix procreate export when smooth shading is enabled with inverse culling or flip matrix
usd: fix crash when exporting an usd with hidden group nodes with children
usd: fix zbrush usd color space
voxel: fix crash for high resolution (~1200)
voxel: improve performance for high value
brush: tweak brush behavior, add more normal filtering option
brush: improve performance a bit
brush: fix falloff editing in symmetry mode
brush: layer tool improvement for lock radius mode
postprocess: add stupid color tint to ssao and bloom
postprocess: add options and improve curvature effect
postprocess: fix pixel art render export keeping correct pixel size
postprocess: remove full resolution option (always on)
postprocess: denoiser is not saved anymore in project or general settings
shading: improve screenspace soft shadow, especially for point light
scene: add separate layers option in scene menu to split layers into multiple objects
scene: add join layer option to joint multiple objects into different layers
pressure: change default pressure curve for brushes to take into account light pressure
pressure: support pressure greater than 100 percent, can be turned off
camera: add alternative trackball option
camera: when the camera is locked through the corner cube, the reference will be sync with camera movement. This is meant to be used with an orthographic camera.
curve: add an option to not merge automatic points
project: make sure to keep the current active project when deleting another project
facegroup: add option to generate face group from uv islands
gizmo: fix pivot wrongly being reseted on multiselection
mirror: add more mirroring options
2.4
ios: fix crash on older ipad
layer: fix crash on clone
ios: add back language selector in Settings app
ios: fix nomad file thumbnail on iOS File app
ios: pencil double tap hotkey now forces toggle
ios: reuse previous render preview
crash: fix crash when decompressing legacy data
interface: fix fonts and text not appearing correctly
interface: fix warning icon positioning at the bottom
interface: floating window keeps their position more consistently
pencil: increase interaction threshold for tap
reference: fix jittery translation syncing
gesture: added transform tool to interaction filters
export: make sure that export count is the same as actual export
tube: fix point not being able to be dragged with very small radius
layer: join as layer now only pushes one undo instead of two
android: fix virtual keyboard for binding search bar
scene: fix random crashes and freezes
reference: keep roll when unlocking
voxel: add 100% relax pass
grid: fix snapping with large scene
move: fix normal deformation with object with non uniform scale or skew
interface: fix crash when using binding search bar
interface: fix gamepad button bindings
interface: add collapse all button in scene menu
interface: multi material editing was sometimes broken when selecting instances
ply: fix faces being sometimes flipped on export
stl: fix faces being sometimes flipped on export
fbx: improve export with non uniform scale, skew and layers
gltf: improve loading speed for files with many facegroups
usd: improve support
interface: fix slider issue with tooltip
tube: add normal snap option
usd: fix crash on export and import
scene: group lock will now lock its children
boolean: fix random crash
input: fix second single tap sometimes not being recorded
reference: simplify reset view on unlock option
reference: fix transform mode going crazy when reference is locked and rolled
• New tools
  • Elastic and Polish brushes
  • Arrange: spread objects along a line, circle or sphere
  • VDM brushes: capture a VDM from your sculpt, sculpt a new one, fix existing ones
  • Text primitive with Google Fonts
  • Link: live sync with Blender, ZBrush (GoZ) and other Nomad devices
• Sculpting
  • Stroke trail, random intensity and color
  • Hold a stroke to snap it to a shape
  • Separate area and falloff normal filters
  • Tiled symmetry, symmetry from the pivot
  • Fix alpha: flip, rotate, clean borders
  • Nudge fold, Smooth keeps borders, Trim keeps topology
• Curves and primitives
  • Edit curves with the Move tool
  • Curves: IK, sharpness, bevel and warp
  • Spiral presets: rope, braid, ribbon, strands
  • New cap fills and rounded caps
  • Surface repeater: scatter copies on faces or edges
• Mask and selection
  • Gizmo pivot reset: mask, center, top, bottom
  • Improved Lattice: point selection, soft radius, rigidity
  • Mask grow, shrink, border and cavity
  • Face groups from UVs, normals, parts or mask
  • Measure: shortest path and cross-section
• Topology
  • New Autoremesher and UV unwrap
  • Bake from multires
  • Voxel remesh: edge length, thicken thin parts
  • Decimate: preserve borders and painting, uniform faces
  • Split by parts, groups or layers
  • Clean overlaps, weld radius for positions and UVs
  • Extract: bevel, gap and wall profile
  • Trim, split and project on several objects, with masking
  • Better hole filling
  • DynTopo keeps UVs
• Painting and rendering
  • 25 layer blend modes
  • Texture curves and material picker
  • Volumetric fog
  • Poly Haven environments and textures
  • Radial and sky gradient backgrounds
  • Depth of field aperture mode, better SSAO, render with transparency
• History and files
  • Save the history with your project and replay it
  • Export with embedded assets and history
  • Import: merge duplicate positions and UVs
  • STL for scenes over 50M triangles
• Interface and input
  • Customize the interface: colors, glass, accents
  • Reorder the top menus, HSB and RGB color sliders
  • Snap to grid and to points
  • Reorder cameras and lights
  • Gamepad, SpaceMouse on Mac, trackpad gestures
  • Apple Pencil: more precise on lift, tap while hovering
Nomad 2.10
• Paint
  • Paint with shapes: line, band, lasso, polygon, rectangle, ellipse
  • Band: a gradient between two guides, shaped by a curve
  • End material and feather for soft gradients
  • Shapes stay editable with a live preview
• Mask
  • Mask and SelMask merged into one Mask tool
  • Feather on closed shapes, gradient masks with Band
• Material
  • Displacement maps displace the mesh live, Apply turns them into geometry
  • Bake and inspect displacement
  • Displacement import and export for OBJ, USD and FBX
  • Create a material preset from the selected object
  • Tube IK: tap a point to lock it, long press to lock all
  • Spiral: Spin can change along the curve
  • Shapes follow the curve type, Bevel rounds the corners
  • Handles show their value while you drag them
• Repeaters and Arrange
  • Surface repeater: tap the object to toggle face groups
  • Consistent tile orientation and faster scatter
  • Faster display of many copies
  • Arrange repeaters and groups as one item, circle and sphere without overlap
• Gizmo, background and history
  • Rotation snap: any angle step, new Magnet option
  • Linear background gradient with an angle
  • History replay: camera smoothing
  • Shortcuts to open any menu
  • On tap: choose finger or stylus for tap actions
  • Double tap the intensity slider to reset it
  • Blender Link: displacement and pivot sync
  • Holding a key no longer repeats its shortcut
