Hi anybody familiar with scale or measurements, is there a way to see what scale working in object size etc?
Or is it not available in the app I can’t seem to find it.
Thanks in advance!
Thanks in advance!
The only way to do it is to create a scale reference
So if you want something 7 feet long, make a cude with a xyz of 7 and work accordingly
I ‘believe’ that nomad works in millimeters (dont quote me on that though)
Thanks a lot for the tip Garyforce! We have to work around then.
However it would be nice if you have a parameter for wall thickness and so on. For printing parts you can always scale back in another program. Just another way of thinking.
To be fair its as @stephomi says… 1 is the most logical unit because 1 can be anything ![]()
Just then work to your own scale and use the exact measurements when you need that kind of accuracy.
G
Thanks Gary I get the point, I work around it ![]()
If you’re trying to get the measurements for printing, What I like to do is send my stl file to Microsoft 3D Builder then scale it there. I use 3D builder to fix my models before printing anyway which I definitely recommend.
now if that’snot the case well then I have no good input lol!
