Hi, just started with nomad, i watched a lot of tutorials before but none of them helped.
I want to make a wall with a hole in it. Like a prison window with bars (the bars will be added after). There will be no glass, just a hole. The thing is, i want to do the hole shape manually (by hand) not a perfect circle. I tried with mask and split but there are 2 issues :
- After splitting , the wall becomes more like a cube with rounded corners (simply can’t understand why)
- The wall is empty inside, is there a way how to fill up the wall before making the holes? I don’t want to crop the surfaces, i 'd like to make a “tunnel” let’s say, but the inside-wall to be filled up.
