Hi,
so I did one leg of a model and want to copy another leg. Is there a way to select, copy and paste?
Thanks, Yes I donât want to mirror from the start. I scanned this object and brought it into nomad. One leg was fine the other was crap. I want to copy and paste the left leg ( duplicate it )
If you donât want 2 left legs then a mirror would be a good option
Um yeah but I just want to clone that bit, and sculpt it. I can rotate it.
Clone is the âcopy & pasteâ function youâre looking for - go to Gizmo tool and select clone on the left menu. Then move the object using the gizmo & youâll end up with a clone. Canât clone a part of an object, so need to clone and chop off the bit you donât need.
