Hollow for head
Salve vorrei chiedere se è possibile avere la funzione Hollow come in Meshmixer.
Grazie
Yes, I used to use Meshmixer for hollowing out jewelry. Now I use the shadow tool in Nomad. You have to shade the object first, then go to the brush menu and use the options to pull material inwards or outwards. There are options like extracting solids or shells, just like in Meshmixer. If you pull in one direction, you only need to enter the thickness in millimeters, but if you pull in both directions, the number you enter will be split in half. There are many options to experiment with. It’s worked perfectly for me, and I don’t use Meshmixer anymore.
