The scenario, creating a tire, stamping tread on the tire, and that obviously change’s the object’s centre of mass, so the gizmo moves to the new centre, I have a couple of ways I recenter the gizmo on a lopsided object, but just wondering what the simplest way is, Thanks
Hey, when the Gizmo tool is selected have you tried to switch off ‘Local’ from the side bar?
I just found that looking around, thanks very much exactly what I needed!
You’re welcome!
Radial symmetry is an option as well. The seams are challenging with stamp though.
I modelled the profile with primitives and used insert together with radial symmetry here:
I think @Holger_Schoenischka aka ProcreateFX made a tutorial on YouTube how to do it….well I would be surprised if not.
Edit:
Yes, radial symmetry. Don’t forget to uncheck the mirror plane in symmetry options. Use radial only and use a seamless pattern
Oh wow nice wheel! and yeah those seems are definitely a challenge, thanks for the great tips, definitely helped a lot.
