Apologies if a similar operation already is in place, but haven’t been to find it.
Cheers
Cheers
Do you need the point for the camera as center point or for the gizmo to move / rotate mesh … as new center point ?
No, it’s not about camera or viewport.
I am trying to use object X as a centrepoint / pivot point to rotate object Y.
I have attempted to see if the “Stab” options could do anything, but haven’t found out how it works / what it does. (ie. tapping on object X while in “custom pivot” mode with “stab” activated, just selects object X)
Am I doing it wrong?
It is not possible to place the Gizmo exactly on the center of another object by tap - manually it is possible. You need a small division at object X to get some kind of crosshairs when the wire is on.
If you want to use the radial symmetry as a center of rotation on another object, use the Insert Tool + Clone + Snap and then the Gizmo.
Thank you Holger. I do it in a similar way to how you explain it in the video, but that is also why I asked for a function in the Feature Requests. Could make things like mechanical sculpts a lot faster.
