kokeshi doll
Made on iPad Pro first gen.
Took some figuring out to get this over to Procreate and back again, I think it turned out all right for a first real attempt. Still lots to learn.
kokeshi doll
That‘s sweet.
To make first steps a bit easier:
You can consider to stay in Nomad and paint your model via vertex painting. Vertex is a single point connecting polygon edges that build your object geometry. For painting in Nomad with details like you made up there, you only would need higher mesh density.
Could be achieved by simple subdividing. Remember, each subdivision double’s your object vertices and memory use. Do not do it woodpecker style
Integrating Procreate if you want to use very special brushes could be something to do later.
