Bug reports
AO is broke on all my projects along with curvature - latest version. iPad Pro
Bug reports
Are you sure about the AO?
Yep all
Projects including blank new scenes AO does nothing at all.
But what do you mean by blank new scene? A sphere? What are the parameters?
New scene, add anything ( sphere, cube, old model, new model, pbr + matcaps) turn on AO it does nothing. All sliders do nothing.
Also painting is not working properly I have a lot of models not accepting any brush paint. I can flood fill but hand painting isnât working in âsomeâ situations. Iâll try to debug tomorrow if I have time.
Ao is working fine, and painting as well. Iâm pretty confident about these two. Only the curvature is completely broken.
(Unless you got an Android device with a specific graphical bug but thatâs another story).
For paint, double check you are not on a layer or with depth filtering enabled, or that the model has masking.
As for AO I need screenshots, if you only have a primitive on your scene obviously AO wonât have any impact, like before.
Ill send images soon. But yeah I understand the AO logic, I use it everyday⌠It is doing nothing. Unchanged. At all, no darkening. I may try to delete and redownload. But I can assure you for me itâs does litterally nothing at all since the update.
Better than screenshot would be a small project, that way I can have all the settings.
Make sure to disable curvature.
Note that the compositing for AO changed slightly but only for unlit and matcap (and it should be subtle Ambient Occlusion is desaturated - not responding the painting information - #2 by stephomi)
I have non of your issues except curvature. iPad Pro 10,5â 256GB
So I am wondering if itâs your iPad, or your Nomad installation?
I am sure you have done all regular iPad shit like:
Switch it off/on
Do a force restart , on my old iPad itâs holding off button+home button for several seconds.
For devices with no Home button:
This can help. A complete backup and reinstall is something I wouldnât do one day before a deadline.
Havenât heard of a single time where a nomad reinstall was useful.
The only thing that might be useful is to rename/delete some folders in Nomad folder, itâs basically the same as a reinstall.
Good news for the painting however thatâs all good after a close and reboot of my iPad. AO however didnât fix with that
Ok. .AO âmaybe fixed???.
AO is broke UNTIL I add a NEW primitive to my scenes. If I add a new sphere all settings turn back on. Then save the scene and it stays. When I do this for each scene, it fixes the AO.
Why do you think that is?. The new object kicks the post back into working somehow?. That is also what fixes the paint issue in my scenes. Adding a new primitive.
Weird but relieved those are fixed. Once curvature is back Iâm good to go!
Refractive objects are not taken into account for AO, same as before (I just checked to make sure, but it supports shadows and dof though).
If you can reproduce the bug with only opaque object, just send the me file (Files â export glb â mail stephaneginier@gmail.com).
What is the paint issue? Just send me a file with a reproducible scenario. Itâs a bit confusing so far
Almost 100% sure itâs not the reboot that fixed the issue (just rebooting Nomad should be enough).
It was probably an option somewhere.
