Hi
I wonder how do alpha images work. In the manual, it says that black is neutral / no deformation.
I thought that mid gray like #777777 would be neural, and everything above would create a negative deformation, and colors below would add positive deformation to the object.
Let’s say I would like to create a “door” on some metal, the “door” have some vents openings. I would like to have the border of the “door” to be negative, cut into the form, but the vents openings should be positive - coming out of the form. Is that possible to achieve using alphas?
