Please add import image as an texture.
This is the wish of many Nomad users, but Stephomi made it clear that this was unfortunately not foreseen in her roadmap. The problem with textures is that the object must have UV coordinates and above all also your object must not have a mesh with millions of polygons because quite simply no tablets would not support that. By cons as I said yesterday in another post there would be a way to use an automatic uv unfolding. But there is also another simpler trick like in zbrush is to be able to use a color texture to paint the vertices quite simply.
