Weird paint artifacts, and materials are too dark in material panel
I opened a file that I worked on a month ago, I noticed the paint of the model has changed, with weird roughness artifacts and splotches that weren’t there last time I closed the file, also the material panel looks weird, were all material are very dark.
I an having the issue with the overly dark materials in the material panel as well.
Yes it’s a know issue, I’m changing a few things in the painting.
I’ll soon make a release, if you don’t overwrite your file it should be good for next release.
If you update to Nomad 1.40 it should be good.
