VSync turning itself back on
THE PLATFORM: Windows 11
NOMAD APP VERSION: 2.9.27
I have had an issue with system lag when using my tablet in Bluetooth mode in Nomad. Only a system restart fixes the problem. I need to do more testing, but I have had two sessions so far with no lag when I turn VSync off in Nomad settings.
The problem is, when I check the setting at the end of my session, Nomad has re-enabled VSync in the settings. I’m not sure if something specific causes this to occur or not, or when exactly it happens. I currently Alt-Tab a lot between full screen tutorial videos and Nomad, but not sure that matters or not (I’ve checked a few times when Alt-Tabbing and VSync is still off in Nomad). The setting correctly persists between sessions, it just seems to turn itself back on sometime during the session, until I disable it again.
Yes, will be fixed.
