Can't change apps when full screen mode is enabled
THE PLATFORM: Windows 11
NOMAD APP VERSION: 2.9.29
I’m unable to Alt-Tab or use the Windows key to switch apps, view the desktop, view file explorer, etc when I run Nomad in full screen mode. Most full screen Windows apps allow you to do this (even games). Other than bringing up the taskbar temporarily with the Windows key, the screen is locked to Nomad.
Are you using single monitor?
I am using multiple monitors and I do not have that problem.
I was trying to replicate your issue and now I have the same problem.
When you move Nomad to the main monitor then you can NOT switch to other programs or apps.
To be available to switch to other apps then we need to turn of fullscreen in nomad.
Thanks for replying and verifying. Yeah single monitor setup, I just use my tablet as a pseudo second monitor occasionally, but still need to alt-tab quite a bit on my main monitor.
I think this should be change. Even if I have multiple monitors if Nomad is in my main monitor ist hen over.
I hope this will change. :grimacing:
