Fullscreen No Working Properly
THE PLATFORM: Windows
NOMAD APP VERSION: 2.8.2
Hello everyone,
As stated in the title Fullscreen is not working properly on my set up. I am using a screen and a pen tablet display (Huion Kamvas 16 2021). Nomad correctly enters fullscreen mode on the pen display but whenever I mouse click outside of the app (i.e. on a web page opened on the main screen) it minimizes.
Has someone ever had this issue?
Thanks in advance,
Ellepy
Full-screen mode does indeed cause problems. When I name an object, for example, Nomad minimizes to display the dialog box where you enter the name. Once I confirm the name, the dialog box disappears as expected, but I have to manually switch back to Nomad, and the display is “crushed.” To restore the normal display, I have to switch to another application (Alt+Tab) and then return to Nomad.
I’ll take a look.
Note that you can use an alternative dialog for inputs (interface → use nomad dialog)
When I enable the “nomad dialog” option, everything works perfectly :wink:
