As usual I hide the cutter object, then select the target and the cutter and voxel remesh. This time Nomad just join the two. I tried in a new file with two different object and it works. Maybe I’m missing something? Can you help me ?
If you can simply send me the file and I’ll be able to fix it (if I can replicate the issue)
(support email in Nomad about menu)
I sent the file via e-mail, let me know if you can fix! Thanks a lot !
Thanks!
Found the issue, it will be fixed.
So for now what can I do (first time for me to have beta access) ?
Voxel remesh the hidden part first, hide it and then do the boolean.
It works, thanks !
