Updated to 2.0, some settings reset, won’t save bottom bar changes
Bug reports. That’s basically it. I woke up to a new Nomad 2.0, and my tool bar was back to the big 6 column view. I changed it back then noticed my bottom shortcuts were all reset too. Changed those. Everything seemed fine but after closing my apps, and reopening Nomad, the toolbar was fine, but the shortcuts were all reset again. Any ideas?
Hello,
How did you manage to reduce the number of columns, I cant find the slider anymore ?
t’s a bit odd, but there’s a new icon in settings that says UI, activate it, then drag the big one at the bottom of the toolbox to where you want it.
Sorry, I found the answer myself, using the widget on the left bottom of the brushes window.
You were too fast ! Thanks anyway !
Bottom bindings are very nice. Although, every time I quit and re open the app, I lose some icons : specifically "Persp’ and ‘Verrouiller’ (that is in french, ‘Lock’ in english i think).
Maybe I exceeded the max number of bindings ? I dont know if there is a maximum.
What does the last item says? → Nomad Change Log - #75 by stephomi
I am not sure to understand the question. My last item in the bar is ‘Mask Sel’.
Did you click on the link…?
That’s the Nomad change log, 2.1 version says “fix some bottom shortcuts not being saved”
Yes i clicked and saw that some corrections were made, hopefully completely fixing the bottom bar.
I’ll wait for the next update distribution on Apple.
Thanks. I didn’t know about this page. I’ll keep it bookmarked.
I just got the update. Everything is working ok. I must say, with this addition and the ones before, the app UI is now almost perfection !
