Огромная благодарность!!!
…But this no help
Try to update iOS, there might be an issue with older iOS version.
Nomad still crashes after being on iOS 15? Or renaming the folder?
Hi there,
IPadOs 15.1 - Ipad 9th gen - working Perfect.
Thanks for the new feature.
Absolutely no brainer here.
Worked perfect.
Old iPad 10,5” 256GB 12GB free
IOS 15.0
The app is crashing as well?
What is your iOS version?
Rename folders… App No live (
Your iOS version?!
ios 13.3.1
iPad Pro 9,7 1st gen
Ok then, if you can try to update your iOS version.
I think that’s the issue.
Otherwise you’ll need to wait for the next Nomad version (and hopefully I’ll manage to fix the problem).
IOS 15.1 is available for ipadPro 9,7” , as a bunch of people already said the upgrade solved their issue. it’s a very good idea to try this first. If you are still on IOS 13 it’s time anyway.
Maybe it belongs together with more free RAM available with iPadOS 15 but not in older IOS? Not that older device would profit, it’s just an idea.
Everything is fine, I updated the firmware, the program works! Many thanks to everyone!
Ok I managed to replicate the bug by using an iOS simulator on iOS<14.
I’ll try to fix it quickly, but otherwise update your iOS!
Thanks so much if you can fix this bug for iOS<14. I’m stuck with a classroom set of ipads on 12.5.5, and Nomad stopped working on some. I love this software form my 3-8th grade STEM class and hope to be able to continue using it heavily for 3D modeling and printing. Thanks again!
You did it! Thanks so much!
