I have read the manual, but I have not figured out this is possible.
I have added a cylinder, rotated it into place, but then I find out that the cylinder is to short, so I try to use the Gizmo tool to scale on the length axis, but as the Gizmo is not rotated when the object is rotated, the object gets deformed and not just longer. Is there a way to get the gizmo to “transform with the object”, or do I just need to unlock the gizmo, and then manual rotate the gizmo?
Edit: it seems that I can’t rotate the gizmo, only move
