Hello everyone, this might be very basic but I needed help with this
I have duplicated upper arm part on the screen right and flipped it. but when I select the flipped object (circled in red) the gizmo tool stays in the same position as before it was flipped, is there a way to get the gizmo tool to flip with the object?
Did you mirror the object so that both side are one piece or is it a separate piece?
While using the Gizmo tool, there is a Pivot button on the left toolbar. Tap that and tap one of the options or move it manually.
Ah they are seperate objects, but the pivot tool worked perfectly! thank you so much!!
