Bug reports。圆管工具拉伸以后,重新拓扑,网格不会均匀
I’m not sure it should be considered a bug.
You could have an instance of this mesh with another transform without non uniform scale.
In that case it’s impossible to have uniform density in both case.
Probably best to bake your matrix.
谢谢你这么快速的回复,但是圆管工具做头发会很好用,网格重构不能均匀网格的话会给对后期雕刻影响很大,如图
Clearly you didn’t understand what I said.
Bake the matrix before voxel remeshing!
