Stamp height adjustment
Hey Stephan,
So what setting effects the edge height of the alpha? I assume it’s the Falloff? So I’d like the hatch part line to be flush with surface.
Also, I assume this is where the strength of dynamic resolution comes into play?
Thanks!
Alan
Did you try toggling “Invert value” on top of the alpha widget?
Yes but it seems there is an issue with the Stamp tool.
Until it gets fixed, you can try with the “Clay” tool while enable “Grab - dynamic radius”.
Update: well dynamic topology doesn’t work well with “Grab/Stamp” tools I’ll need to improve that part.
Thanks.
Yeah I’ve been playing with the invert as well.
I will try your other suggestion.
Btw, LOVING this app! Thank you for your hardwork!
Thanks,
Alan
