@mestela Thanks. Yeah, that was a little while back. If you look at the date, it was a bit over 2 years ago. At the time, Nomad was adding things seemingly monthly. But, depth painting wasn’t in yet. Was just a quick suggestion and he had it prototyped in a few minutes. Took a bit longer to get it in one of the published builds, but it works quite well. I do use it quite often in certain areas though. Makes things go so much smoother and quicker than trying to do it with a small brush by hand.
@Nick_McDaniel Anything is possible, but I’d have to consider numerous possibilities before saying one way or another.
File this one under random things you can do with Nomad pretty quickly.
Some more alien/creature doodles.
This one has been sitting around for a while. Finally added some color today and figured I’d add him in here.
Finally watched @Holger_Schoenischka video about the curve repeater. Used this sketch to try it out on the upper horns. So nice and quick to use. Wish this was around when I made my centipede.
And another head that should fit in here.
