Shortcuts or tips to improve workflow
So I recently learned that I can hold down the mask icon and click off my object to invert my mask or drag to erase it. (Just like Zbrush). I’ve been using the menu for a loooong time to do that before. Anyone else discover little time savers like that they’d like to share?
If there’s a way to blur or sharpen a mask without going into the menus that would be a life saver too.
Hold smooth and you can highlight multiple objects easily. A quick way to delete a mesh is to use the delete key on a keyboard. :+1: there’s a couple others, these are the most useful though (and the Mask)
You forgot sharpen and blur mask, depending if you tap on masked or unmasked area while holding mask button.
My tip, never forget the manual.
And
-three fingers up-down for brush size.
-drag over select square in scene menu to select multiple objects quickly.
-tap on stats to collapse or extend stats for each single object vertices or collapse scene vertices and selected object scene vertices only
-tap and hold on navigation cube to lock cam orbit. Tap again to unlock.
-tap on navigation cube to snap to plain front, top etc. view.
-to mask single objects after simple merge multiple objects, hold smooth and tap.
-three finger drag to rotate environment & lights
-tap tool once to activate, tap a second time to open save and clone menu.
