It would be very convenient if someone like me who had purchased on both ipad and pc and would like to work between the two hardware. Maybe a button if hooked up to the same network to pass files between the two. Similar to how goZ had done between their ipad and pc workflow.
You can get iCloud app on pc. Then just copy/save your project files to your iCloud and you’ll be able to access them on both iPad and pc.
oh yhea I totally understand that as a solution. But when it comes to min-maxing valuable time with no friction, it be a saint. Every minute counts. Especially in workforce enviroment.
I use localsend. A free perfect App who use wifi direct transfer.
I usually just use iCloud Drive or AirDrop for this and it’s been pretty reliable. Exporting as OBJ or GLTF also seems to avoid a lot of compatibility headaches when moving between iPad and desktop apps.
