The default voxel remeshing resolution is set at 150 for all new pieces of geometry which are added to the scene.
Would it be possible to include an option in settings so we can change this default remeshing resolution?
My reason for requesting this is that I often want to add geometry and work with low resolution remeshed parts to block things out.
I guess this might sound like a needless request as you can easily just add geometry, click the topology tap and reduce the resolution slider from the default 150 before remeshing everytime. But if you would be happy to add an option to adjust this default setting I would personally be really happy and make my blockout process slightly smoother than it already is with this great app.
Thanks for your consideration either way.
