Select mask only the front surface
I’m not sure if this is just something I’m missing but when using select mask it selects straight through the mesh. Is there a way to use the select mask only on the front facing surface without it going through the mesh?
For the brush mask there is an option in the stroke panel called « front facing vertex only ».
It’s not available for selMask at the moment,
Maybe you want to use « connected topology » depending on what your scene is.
Is this feature currently available now or are you considering adding it? It would be really usefull
It’s been in Nomad for ages now. When you choose a brush, and click on the brush properties, the tab that looks like a pen has an option for ‘front facing only.’ You can do that with any brush as far as I know.
Thank you for replying. I saw this in a tutorial maybe the day after I wrote it. Actually, I thought of deleting what I wrote after I found it, but I decided to leave it because I was a little lazy and maybe it would help someone. Thank you again
More than welcome. I think you were right to leave it - I used to see similar questions on the Facebook groups pretty often, so it’ll definitely help others.
