Rotating object by a exact degree
Hi there, is it’s possible to rotate an object by a fixed degree.
For instance I need to rotate a plane at 45 degree angle along an axis currently cant find how to do it precisely?
You can use the slider on the left when you select the gizmo.
It would be nice if while using the gizmo on screen we could constrain to 22.5, or at least 45 deg increments using multi-touch. Many apps have it so if you use the Apple Pencil and a finger or two from your other hand pressed on the screen to rotate you get rotations to snap to those angles.
Maybe this is already in Nomad though and I haven’t figured it out?
When using the Gizmo, there is a slider in the top-left. This can be set from 1-90 in single degree increments. This means you could rotate it every X degrees as desired. Just no 1/2 degrees as you mentioned.
