Reset camera
Hello, I’ve done something to my camera/model that requires me to constantly refocus on various parts of my model when I rotate. This is a new issue that just started happening. Before I could rotate, zoom in/out, etc. and the model never lost focus. Now only parts of the model are in focus (not blurry) unless I tap or dbl tap on another part to bring it in focus. Again, I’m sure it’s some setting I’ve triggered but can’t figure out how to undo it. Any ideas?
Thanks in advance.
Did you try the post process area? Try disabling depth of field if it’s on. That’s pretty much the only thing that I can think of that makes any part of the image blurry in that way.
If it’s not the depth of field in post process then it might be the double tap focus under the camera settings that zooms in on the current selected model.
that worked! thanks so much! i was having the same issue and couldn’t figure out what i had pressed. it was perspective in the bottom section! thanks so much!
