Things like this:
I would like to see these post-processing effects implemented in the future releases, if possible -
A half tone effect with the ability to change the pattern with a bitmap/image would be great.
A shader based outine effect with threshold (I know that existing curvature effect can be somewhat used for this purpose)
An anisotropic kuwahara filter for water color effect with threshold.
A simple lens distortion effect.
The existing chromatic aberration effect works as intended, it would be great if it can take lens distortion into consideration and ability to change the hue of the effect.
The existing depth of field effect works as intended, it would be great if we can control the shape of bokeh using a bitmap/image along with threshold and brightness control for the bokeh.
The existing bloom effect works as intended, it would be great if we can get a convolution bloom effect with ability to change the bloom kernel using a bitmap/image.
Other than these effects, a layer based post-processing stack would be great with an ability to re-order the post-processing effects…
I know this will require a lot of work to implement these… So, it’s upto you…
Cheers!!
