Nomad | combo sketchbook
Learning / touching for the first time nomad.
Sculpt maybe 10 min.
Searching on the web around 2 hours. :sweat_smile: This is the way! LOL! :collision:
Can I post here nudity? Or screenshots like these ones? :grimacing: :thinking:
Learning more and more …
Ok !
I will leave this as it is for now.
I found couple of this that aremissing and do not like and MANY things are COOL!
LOVE NOMAD!
:collision: :tada:
OOOO! This will make a lot of fun!!! HELL YEAH!
ALMOST THERE!
Space Mouse TIME!!! :tada:
YES!
Enough of programming! Now is time to work! :thinking: :grimacing: :sweat_smile:
Ok for today in a few these this can stay good enough.
I can use the 3dxconnexion mouse but not 100% correct.
After a lot of coding finally I could make my artistic tries! :sweat_smile:
To understand what is going on here.
I sculpt the car inside nomad. you can see some images at the beginning of this thread.
Then after sculpting I brought the car in Maya to remesh. I do not have the quad remesher.
Since I use mainly zbrush (IN THE PAST) now NOMAD to build my stuff and I could not clean the surfaces inside Nomad, because I am a Nomad beginner using Nomad, then I took the Maya surfaces to clean the sculpt I did.
And now I have a perfect clean decimated result to work with and star to define and shape more the car.
It needs some clean up but DAMN! NOMAD IS SOOOOOOOOOOOOOO COOOOOOOOOOOOOOOOOOOOOOOL!!!
This is the original decimated result, but cleaned.
Some areas are not visible good, but this is model in which I will continue to work.
And now thanks @2ndHouse then I can polish the surfaces as I normally will do in zbrush but in the AMAZING NOMAD!
The start was like this.
Then sculpted like this.
DO NOT DO THIS AT HOME! :grinning_face_with_smiling_eyes:
I changed the back of the car because i did not like it at the end and the side too.
I need to try more! it is NOT easy!
Butfirst rims with nomad.
Well first tires! lets see.
OH FORGOT!
No AI involve!
Since my brain is burning I made a small brake.
I just had fun doing this.
Back to the rims!
COOL! I did not use any reference at all. I was playing around and I was not that off.
Now is time to model properly!
In case you need BOOKMARKS follow the link below.
Finally I can start.
Some hands and then we start.
DAMN! I am slow.
Time for the face!
I will stay in the face for a while.
OK! For today is OVER!
CHEERS!
I could not see her without ears.
So I did some ears fast.
I had only 1 hour to continue. DAMN IT!
Face is not the final but at least I updated. Upper body updated too.
I will do next the arms and legs.
Now only. Elbows, feet and hands.
DAMN is faster than zbrush.
Doing some test.
@Jnjn
I know you like zSpheres just like me, BUT this is the equivalent to zSpheres in Nomad which is COOLER and FASTER!!!
I was build extremely fast so no time to adjust things properly :see_no_evil_monkey:
Time to switch a bit.
I need a break of building her.
I wanted to sculpt this guy for soooooo long!
It is time to build this guy!
Sketch Β© Taran Fiddler.
His work at:
https://www.artstation.com/tfiddlerart
At least I have made the head already. LOL!
Continue soon later.
