Need help in fixing topology
Hi! Love nomad ! Am new here and hope someone can tell me how to fix this surface ? Model was imported and has this ? Thanks
I was able to fix it with the pinch tool but i am still unhappu about the surface , some triangles are bigger and it shows it’s been pinched.
I’m wondering if there’s a mesh that’s popping through it from within? Maybe take the mesh into 3DS Max max / blender and carefully inspect the model, make sure there are no vertices directly on top of each other and delete them.
There’s a second mesh shining through, I think. Set material to additive with the wire frame on, then the object is transparent - maybe you can use the Move tool with a very small radius to align the points individually again…or delete the other Mesh…
Thank you!! :pray::pray:
Will definitly try million thanks!! :grinning:
