Thank You @Matt_Sargent
The motor bike leaves me speechless!
Thank You @knacki.
Iâm pretty sure I have no clue why on earth I make this diamondâŚ. I was making my project (fan Art) suddenly I make diamondâŚ
I canât get your latest video to play unfortunately. The player is there but nothing plays.
Same here. No video, player only . On discord I can see preview, but canât play neither.
@Adam @knacki its works for me from safari, chrome, discord on my iPad. Iâm not sure why.
I want to upload the original file but too big. Perhaps issue when upload from file instead gallery?
Let me try again
I give up if doesnât work again.
Just a blank player with no preview thumbnail. The aeroplane video works.
Still post a render. Interested to see what you have posted.
Thank You @Adam.
Well itâs a diamond though I donât have intention to make one. Maybe cause I make accessories so I thought about diamond.
I think if refraction setting can up 2.4 instead 2 it will perhaps more like Diamond.
Thatâs just my thought.
The only way I found to amplify the refraction effect is to do an inner layer with flipped polygons with refraction and double sided. You can then play around with refraction settings on two model layers.
It adds a little bit of extra dimension.
If you have two inner layer models each scaled slightly smaller you can get a better effect.
Ah yes I know about 2 object, but doesnât give closes effect. Since itâs literally more like crystals rather diamond. And yes the render was one object.
Perhaps depending on the shape it self. Since yours is round.
I was thinking to use 2 object but different shape.
Literally like try to make the inner part of the diamond.
That different shape might work well. Itâs very hard to replicate glass and crystal in Nomad. Itâs going to take a lot of experimenting.
Interesting to see how your diamond turns out.
Hey guys, fantastic tests. Didnât get Adams double effect working⌠I donât know how to flip normals in Nomad
The real fun starts with different objects around and background image. That time refraction starts to get glorious!
Side looks good for me, close enough I think.
But the top still need to test thatâs looks odd for diamond.
Thatâs a good looking diamond.
Thank You @Adam
And the best possible I could make.
In the end I need 3 object inside the diamond.
The inside is like this.
Top
Side
Bottom
The crystal turned out very nice.
