Missing Gizmo Settings for Uniform Scale
THE PLATFORM: iPad
NOMAD APP VERSION: 2.8
Missing the entire “Matrix” portion of the Gizmo Settings menu, I need to enable the “Uniform Scale” option but it’s simply not available! I’m literally stuck unable to import stls & obj’s to work with existing files because for whatever reason Uniform Scale is not the default. Even the User Manual refers to the option I’m currently missing.
It’s been moved to this button.
THANK YOU!!! I guess the bug is in the manual since it wasn’t updated and still defaults to the old recommendation. I appreciate your help. Problem solved.
