Minor issues in Nomad Sculpt 2.14 (9)
THE PLATFORM: iPad
NOMAD APP VERSION: 2.14(9)
1、There is an issue with the marquee selection when long-pressing the Smooth brush. Marquee selection only works on primitive meshes. If the active object is a polygon mesh, long-pressing the Smooth brush cannot activate marquee selection, though single-point picking still works normally.
2、I have tested multiple files from ZBrush. ZPR and ZTL can be imported and recognized normally in Nomad, but ZBP and ZMT always fail to load. Are there any specific requirements for brushes and materials?
  1. Maybe because you have “Allow air stroke” for Smooth tool. A primitive cannot be sculpted so “Allow air stroke” is not effective there.
  2. The changelog said nothing about ZBP and for ZMT it only said “matcaps”. Some old ZMT can fail to load, etc. Support will be improved but other than that if I don’t have the file I can’t do anything.
1、Confirmed: The Smooth brush marquee selection problem comes from turning on Allow air stroke.:+1:
2、I saw in the 2.14(5) changelog that VDMs can be extracted from .zbp files, so I gave it a try, but it did not work.:laughing:
@UncleBear it’s a bit of a hit and miss for now. Sometimes it works, sometimes it doesn’t. Support will be improved so we have to be patient. My own IMM brush worked, others didn’t .. but it might have to do with how I saved it at the time (years ago) ..
Yes it will be improved, the older ones might not work today.
As for lasso select, I might override the air stroke feature if the user is holding the smooth shortcut.
Maybe some might prefer how it acts today so maybe I’ll need another toggle.
