Masking's on tap feature bug
I don’t know why it doesn’t work at first click. When I use mouse, it works well. But when I use my pentablet, gamon 1060 pro, it doesn’t work at first click. I think it happened right after nomad sculpt’s version update
From what I see it seems you are dragging a bit rather than single tap (and then il will blur the mask.
It doesn’t work when I click it. It always happens when I updated new version. Using with mouse works but pen tablet always works like as if I had dragged it even though I tapped.
Update to latest version (11).
Otherwise go in nomad menu and try to toggle wintab value (on or off)
Thanks for quick reply. But it doesn’t work either. Will it be my pen tablet settings problem? I think I accidentally pressed something in Nomad sculpt
I’m joining the request. I’m in the middle of a project and decided to update. Now, the color selection doesn’t have the same sensitivity as the previous version; it doesn’t seem to detect the touch of my Huion Kamvas stylus.
Isn’t that masking the whole mesh with tap? I’m talking about the face group mask tap feature.
The cursor is moving all over the place in the video, I’m not sure what I’m looking at.
@DESING_RED9 color selection? If that’s the color picker, is it working if you are precise/stable, did you enable the pencil in the gesture menu (for color dropper)?
I tried to fix this several times and found out that this bug only happens when using pen tablet and when mask brush’s stroke style is dot. When I use my lasso mask(my custom brush) it works well even when I use my pen tablet. Other custom mask brush whose style is dot, has this bug but works better than the original mask brush. If it is not my pen tablets problem I hope this bug to be fixed.
Hello. I haven’t explained myself well, I apologize for that. But I’ll illustrate it better with videos. I’m referring to color selection shading with a single click or tap of the pen. In this case, the pen tool is less effective in the new version. It works very well with the self-masking tool, but with the mask tool, which is the one I use with my keyboard shortcuts, it loses effectiveness. As you can see, my settings are factory defaults; the problem is in the new version. I’ll post both versions here.
2.9.8
2.9.13
Mine works like this video too​:pleading_face:. Only original mask brush doesn’t work as usual.
Ok thanks. I’ll take a look.
Glad this got clarified. Bugs with masking tools can be super confusing because it’s hard to tell if it’s a gesture issue or an actual app problem.
Found the issue.
May I ask when it will be fixed?
Soon.
