Mask with Gizmo?
The answer might be in front of me? … but if a mask a primitive shape… and I want to move the gizmo to the unmasked section of that same shape to only rotate or scale that unmasked section, how would I go about doing that?
In ZBrush I can mask a mesh and affect the unmasked part with gizmo. When I try this approach rather than just the unmasked section being affected the whole shape or primitive moves (with the part still masked).
Also grow and shrink mask / soften or hard mask is a feature, or not a feature yet?
You need to check « vertex » checkbox on the left (it will be renamed by useMask on next release, and it’ll be on by default).
As for soften and harden open the « pencil » top menu while the mask tool is active.
Thank you so much for the fast response! Going over to try now
Worked like a charm!
